cmj01
Feb 10, 2022Tutor
Orbi Pro - rather undewhelmed!
This query relates to SXR80 (router and 2 satelites) which doesn't appear on the model list above... Have just set this up and feeling a little bit underwhelmed. I've got it running as a rout...
cmj01
Feb 10, 2022Tutor
Thanks for that.. What I was beginning to suspect. I liked the network segregation but I guess I could probably have implemented that on the home series?
Any recommendations for a good / cost effective firewall / threat detection system?
Many thanks,
Mike
Feb 10, 2022Guru - Experienced User
My home network isn't that complex or needing a ton of security so I make do with off the shelf antivirus/malware and a pi-hole with some aggressive blocking :)
I've tried the armor but found my solution worked better.
So I can't give you a decent business class recommendation. Sorry.
