Noob39
Oct 19, 2023Follower
Orbi Pro AX1800 WiFi 6 Mini connecting to moca and frontier
Hello, Am I able to connect the Orbi to the moca adapter? Or what would be the best way to connect this? Thank you đ and sorry for my ignorance!!
schumaku
Oct 19, 2023Guru - Experienced User
What is the usage for this Moca bridge? Taking the example of the popular <-Verizon WF-803:
Ethernet <-Verizon WF-803-> Coax-cable <-Verizon WF-803-> Ethernet
Simply spoken, it's a long network cable installation for connecting two Ethernet devices
One end will be connected e.g. to a Modem (WAN-Port), the other end to e.g. the WAN port of an Orbi Pro by an Ethernet patch cable on each end.
Of course, you can extend the Verizone Router LAN network over a Moca link, and operate the Orbi Pro in AP mode.
What usage do you have in mind?
