biopticcoder
Feb 07, 2024Aspirant
Orbi Pro Bricked in AP mode after going to firmware
Recently my SXR80 was updated to 4.3.2.100 through the insights app which resulted in the AP being bricked. I tried the following steps. Factory reset using the reset button and selecting AP dur...
schumaku
Feb 08, 2024Guru - Experienced User
- Factory reset using the reset button and selecting AP during the setup.
- Factory reset, then select router (which worked) it then bricked again when I changed it to AP mode.
- Factory reset, select router, then try re-installing the firmware and moving to AP.
- Factory reset, and manually downgrade the firmware. This seemed to work until I tried adding it back to the insight app which tried t update the firmware and bricked it again.
Thank you for your help!
Tells me that some config pushed from Insight is simply not workable in your environment....
