Max_F's avatar
Max_F
R7000 Bricked after 1.0.7.6_1.1.99 firmware
My R7000 never booted back up after the 1.0.7.6 firmware update that I initiated trough the router web portal yesterday. I thought it was still updating when I didn't get a response after 30 or so minutes so I left it overnight but the power status light just kept flashing the same the next morning. When I finally power cycled it I got the same result: flashing power led, once a sec.
So I followed the "http://kb.netgear.com/19841/Reinstall-the-firmware-on-a-router-without-the-setup-CD-recovery-tool" article and I'm getting a TTL=100 response from the R7000 after setting up the network settings manually. The problem is that I've spent the better of my weekend trying to flash the firmware manually and no matter what I do TFTP2 does the "erasing Flash" step and proceeds to "upgrading flash" where it stalls after about 2/3 with the message "unable to get responses from the server" and tries again. Every time. Pinging the R7000 during the update process keeps returning 1ms TTL=100 responses so I've got one window telling me there's no connection and the other that there is. Doing it manually by activating windows TFTP and sending "tftp 192.168.1.1 R7000-V1.0.7.6_1.1.99.chk" displays "transfer successful" but the log shows that it only sent ~200kb at a speed of ~200kb/s out of the 27MB firmware file. Adding "-i" to the command as suggested on the Netgear support forum gets the file to transfer completely and without errors but the router, yet again, never reboots and behaves the same even after >20 minutes of "settling". On top of that after every unsuccessful try I need to reset the router since it stop responding to ping requests which makes the process excruciatingly slow.
I'm still under warranty and am probably just going to return it during the week but having wasted this much time trying to fix a new router is just ridiculous so I wanted to put this out as a warning. Hopefully there's someone who knows what else I could try before I'm forced to take the trip to return it.
PS. I saw a post about the vulnerability a couple of days ago, made a point of avoiding the Beta a couple of days later, but still got duped.
  • Yes finely after a couple of time i fix the problem and the router is working again;)
    C:\>tftp -i 192.168.1.1 put R7000-V1.0.7.6_1.1.99.chk
    Transfer successful: 27975738 bytes in 25 second(s), 1119029 bytes/s
    With the cable it fix the router for me;)
    vxd79
  • JUUUUP i want to thanks NETGEAR R7000 for bricked my hawk modem:( after i update it's take soooooo long but after refresh the page it's say your not connected, i reset the modem but it's never work again try to use some tools but no luck for me :( so PEOPLE DON'T upgrade the firmware, it's going to broke your router:(( a very angy person now :(
    • vxd79's avatar
      vxd79
      So i try this buy the FTDI TTL-232R-3V3 €32.00 euro cable from internet, hope this wil fix it!! ill let you know wheb i have the cable :)
    • HiSpeed's avatar
      HiSpeed
      Guide
      Hi Guys,
      What did you do exactly to upgrade ?
      You have to be careful because firmware upgrade is alway a risky process...
      I upgraded offline my R7000 from my old 1.0.4.18 to 1.0.7.6 without any trouble.
      Even all my parameters have been kept.
      Only the GUI interface required an online update...
      • jguerdat's avatar
        jguerdat
        Guru
        Mine updated from 1.0.7.2 to 1.0.7.6 with no issue either, EXCEPT that it was pingable from the Internet and the selection was grayed out.  I had to reset the router to clear it up.
  • "What did you do exactly to upgrade ?
    You have to be careful... "
    I followed the advice by Netgear and updated using the web GUI over ethernet cable. Nothing else was connected atm except for wan for the router to be able to download the update automatically. I've done this with all my routers since 20 years and never had any trouble. Are you saying that using the web gui is not recommended? Because i think it would be pretty important for Netgear to disclose this.
    It feels like I've exhausted all options over the last two days and am simply dealing with faulty hardware. I've spoken to my reseller and they've agreed to exchange it for a new one or an Asus router in the same price range if I'd like and I see no reason to not take that deal.
    • HiSpeed's avatar
      HiSpeed
      Guide
      Hello Max_F,
      Do you mean you bricked the router after an online upgrade?
      I upgraded offline, I mean from a firmware file stored on my disk.
      May be there is a risk in your case, but I don't know the reasons (bad temp file or other).
      I think it is interesting to discuss this point with other users and/or Netgear support...
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        Max_F If you can still ping the router, I suggest that you try to follow the steps from this link or try another TFTP client.
        However, if you cannot ping the router anymore I suggest that you contact support to get an RMA.
