cpistre
Apr 03, 2018Follower
ORBI pro compatible with RBS40-100PES
hello
Is orbi pro routeur SRK60 compatible with satellite RBS40-100PES
Thanks
Orbi Pro Router does not support and will not pair with Orbi Home WiFi System Satellites.
- jackkwaiAspirant
- mdgm-ntgrNETGEAR Employee Retired
The only satellite that works with both the Orbi Pro and Orbi Home (obviously the satellite can only be connected to one router at a time) is the Orbi Outdoor Satellite (RBS50Y).
The RBS40-100PES is an Orbi Home WiFi System Satellite and not compatible with the Orbi Pro Router as jackkwai mentioned.
