davidcheok
Sep 18, 2019Apprentice
Orbi Pro Firmware update - V2.4.0.114
Just updated the firmware to the latest today. Nothing seems to have changed. 1) 2nd Wifi still gives a third open SSID (initially seems to work but 3rd open ssid appeared again after some time) 2...
- Sep 18, 2019
Did you see the issue on 2.3.5.108? then update FW to 2.4.0.114, still see the issue,
if you see the issue on 2.3.5.108, then update to 2.4.0.114, but config don't change after update, so the issue still happen on 2.4.0.114,
Please disable WiFi 2 and Enagle again on 2.4.0.114, it won't see the issue again,
We will fix it in next maintance release.
RaghuHR
Sep 18, 2019NETGEAR Expert
Hi davidcheok
Thank you reaching Netgear Community.
Are you using Insight app to manage your Orbi Pro for this issue >>>1) 2nd Wifi still gives a third open SSID (initially seems to work but 3rd open ssid appeared again after some time)
For bandwidth management we need to how you have configured. Based on your config we can tell you whether it is working as per the config or not. Also let us know how much bandwidth you are looking to allocate?
3) VPN access puts me on a different subnet (one lower) to my internal network so I cant see nor access my network which defeats the purpose. Need debug logs.
Once again we take all your comments.
Best,
Raghu
- davidcheokSep 18, 2019Apprentice
Are you using Insight app to manage your Orbi Pro for this issue -
No. Using web interface. Insight app Last updated 28th Aug 2019.
What's the difference? The browser directly interfaces with the firmware.
Bandwidth management slider - 97% wireless 1, 2% wireless 2 and 1% guest. Im looking to allocated 5mbits to guest. Is there a formula to this? Whatever numbers i put in doesnt seem to make any difference.
VPN: If my home network is 192.168.1.x, then connecting by VPN on my phone registers me as 192.168.2.x
