davidcheok
Sep 18, 2019Apprentice
Orbi Pro Firmware update - V2.4.0.114
Just updated the firmware to the latest today. Nothing seems to have changed. 1) 2nd Wifi still gives a third open SSID (initially seems to work but 3rd open ssid appeared again after some time) 2...
- Sep 18, 2019
Did you see the issue on 2.3.5.108? then update FW to 2.4.0.114, still see the issue,
if you see the issue on 2.3.5.108, then update to 2.4.0.114, but config don't change after update, so the issue still happen on 2.4.0.114,
Please disable WiFi 2 and Enagle again on 2.4.0.114, it won't see the issue again,
We will fix it in next maintance release.
davidcheok
FMI: https://community.openvpn.net/openvpn/wiki/BridgingAndRouting
That looks like a workaround for a workaround for a workaround. Is it so difficult to do things so that when we open a vpn connection into our network, we get an ip on our subnet? The wireless gives me the opposite problem when i want a separate network for the guest ssid, it allocates ips from my private subnet. Apple's airport extreme did it perfectly with no fuss and no hassle. Here we are given hoops and loops to jump through just to get something to work right. Ive also worked with flashing ddwrt too and those are easy enough to do too without resorting to writing scripts.
davidcheok
Moment you turn on the second ssid, looks fine.
- davidcheokSep 18, 2019ApprenticeOne minute later
