davidcheok
Sep 18, 2019Apprentice
Orbi Pro Firmware update - V2.4.0.114
Just updated the firmware to the latest today. Nothing seems to have changed. 1) 2nd Wifi still gives a third open SSID (initially seems to work but 3rd open ssid appeared again after some time) 2...
- Sep 18, 2019
Did you see the issue on 2.3.5.108? then update FW to 2.4.0.114, still see the issue,
if you see the issue on 2.3.5.108, then update to 2.4.0.114, but config don't change after update, so the issue still happen on 2.4.0.114,
Please disable WiFi 2 and Enagle again on 2.4.0.114, it won't see the issue again,
We will fix it in next maintance release.
evan2
Sep 18, 2019NETGEAR Expert
davidcheok
Sep 19, 2019Apprentice
Hahhaha. Disabling the wifi 2 and re-enabling has solved the 3rd ssid issue.
- davidcheokSep 19, 2019ApprenticeUpdate:
1) Wifi 2 3rd ssid unsecured resolved.
2) Client segregration on wireless 2 resolved
Still unresolved - vpn client on separate subnet
Thank you for the quick responses and help.
Hopefully vpn issue can be resolved in the next update (without us having to resort to alternative fixes).
Once again, thank you.- schumakuSep 19, 2019Guru - Experienced User
davidcheok wrote:
2) Client segregration on wireless 2 resolvedThe client segregation is done on a pure L2 level - no VLAN, no dedicated subnetworks, all devices are on the same IP subnet. This was disputed many times before - not that I like it the way it's implemented.
Hopefully vpn issue can be resolved in the next update (without us having to resort to alternative fixes).Again: This depends on the capabilities of the OpenVPN client resp. the restricted privileges and Kernel access rights available on iOS and Android. The subnet you see is just an intermediate transport network for the VPN. The real disadvantages are in the fact that we have no control on the IP addresses assigned on the VPN subnet, and that Netgear does a many2one NAT for all VPN clients on that subnet, so all VPN clients appear to originate from the same LAN IP address.
Again: This depends on the capabilities of the OpenVPN client resp. the restricted privileges and Kernel access rights available on iOS and Android. The subnet you see is just an intermediate transport network for the VPN. The real disadvantages are in the fact that we have no control on the IP addresses assigned on the VPN subnet, and that Netgear does a many2one NAT for all VPN clients on that subnet, so all VPN clients appear to originate from the same LAN IP address. " -
roughly translates to :
"No, you wont be able to get onto your internal network subnet to access your internal network and the VPN service is simply a tunnel for you to access the internet through your personal network IP address."
Understood. Then IMHO that 'feature' should be removed or stated as such so as not to think the purchaser of the device will have such functionality or simply stated "to access the internet via their business IP." From a business standpoint, its simply irrelevant imho.
