davidcheok
Sep 18, 2019Apprentice
Orbi Pro Firmware update - V2.4.0.114
Just updated the firmware to the latest today. Nothing seems to have changed. 1) 2nd Wifi still gives a third open SSID (initially seems to work but 3rd open ssid appeared again after some time) 2...
- Sep 18, 2019
Did you see the issue on 2.3.5.108? then update FW to 2.4.0.114, still see the issue,
if you see the issue on 2.3.5.108, then update to 2.4.0.114, but config don't change after update, so the issue still happen on 2.4.0.114,
Please disable WiFi 2 and Enagle again on 2.4.0.114, it won't see the issue again,
We will fix it in next maintance release.
schumaku
Sep 19, 2019Guru - Experienced User
You can still reach your LAN subnet over the VPN client connection as pre-configured and loaded from the Nighthawk or Orbi Pro system, even if there is an intermediate transfer subnet in the VPN connection path.
Do a traceroute from the VPN client to your LAN IP ...
No need to argue - the problem is neither with Netgear (I'm not Netgear anyway) nor with th OpenVPN (very popular Open Source VPN implementation).
Android: https://openvpn.net/faq/why-does-the-app-not-support-tap-style-tunnels/
iOS: https://openvpn.net/faq/why-doesnt-the-app-support-tap-style-tunnels/
Nothing that blocks you from accessing your LAN in a routed (and NATed) way. It's just not a "remote" Ethernet L2 interface.
davidcheok
Sep 19, 2019Apprentice
Understood. Thank you.
