Ginosergio
Jul 01, 2023Aspirant
ORBI PRO first install - does not work - incredible lack of support
I bought an Orbi Pro 9 months ago because there was an offer on Amazon and I was buying a new home. Just in these days I am finally in my new home, and now trying to setup the Orbi. The 2 satellite ...
schumaku
Jul 03, 2023Guru - Experienced User
Ginosergio wrote:
I bought the ORBI to have full Wifi coverage of my home. The TIM router can't reach all the surface.
Suppose I am in a remote corner of the home, I have my tablet connected to ORBI Wifi so in the 10.0.1.x subnet.
With this tablet I wish to watch a video that is on my NAS. The NAS is in the wired LAN, 192.168.1.x
Nothing does stop you from hanging the (unknown) NAS network port to the LAN (made up from the Orbi Router LAN ports, from the Ethernet switch connected to that very same network and even on the Orbi Pro satellite you have spare LAN ports available.
What NAS (make, model, firmware) do you have in place?
Is it configured as a DHCP client, so receiving it's IP config from the DHCP server? If yes, just change the connection and restart the NAS. If no, figure out on how you can change the NAS LAN configuration to DHCP.
Ginosergio
Jul 03, 2023Aspirant
Sorry friend
the NAS was just an example. I am a newbie but I have a very complicated LAN, the NAS is in DHCP but the TIM Router settings assign it a fixed IP, and the same for many other things in my house. I can not change my current configurations, it will be a mess, I would pass days to set it up again, and remember which things access what, etc...
If I can bring ORBI in the 192.168 subnet, configuring it as Access Point, that's enough for me
please explain how....
thank you
- schumakuJul 03, 2023Guru - Experienced User
How do I configure my Orbi router to act as an access point?
You can revert the TIM router to use the 192.168.1.1 LAN IP. The Orbi Pro Router and the Orbi Pro Satellites will get a LAN DHCP address assigned.
Afraid, I'm a little bit lost why people buy expensive Orbi Pro kits, wiring everything up to a switched LAN, and using a minimum of the capability.
