lostgear
Mar 08, 2023Star
Orbi Pro Mini includes Satellite as Attached Device even if wired to router
The Orbi Pro Mini Satellite is wired via Ethernet + switch to the same network as the Router (in Access Point Mode). But in the web interphase under Attached Devices the satellite appears under "...
Mar 09, 2023Guru - Experienced User
You put both are wired to a switch.
Is it going
gateway---->SRR wan port--->lan port from SRR--->Switch--->Satellites
I see a lot time where people just connect the SRR to the switch with its wan port and then the satellites.
It needs to have the SRR wired to the gateway with the wan port and then the srr going to the switch via lan port
lostgear
Mar 09, 2023Star
No, it is in Access Point Mode so:
Router <---->Smart Switch <----->Satellite
<------>SXR30
