lostgear
Mar 08, 2023Star
Orbi Pro Mini includes Satellite as Attached Device even if wired to router
The Orbi Pro Mini Satellite is wired via Ethernet + switch to the same network as the Router (in Access Point Mode). But in the web interphase under Attached Devices the satellite appears under "...
lostgear
Mar 14, 2023Star
I see. Is there any reason why this won't work?
Gateway---->Router----Switch--->SXR (wan port)---SXR(LAN port)
--->----satellites?
Isn't it in essence the same physical connection as:
Gateway---->Router---->SXR (wan port)---SXR(LAN port)--->Switch----satellites?
BruceGuo
Mar 15, 2023NETGEAR Expert
If 2 routers (SXR30) are connected, both need to be in "router" mode. If one of them is AP mode, it would have some problems.
- lostgearMar 15, 2023Star
Sorry there is just one SXR (in AP mode) and a Satellite. I just separated the ports for clarity.
So it should be:
Gateway---->Router---->(wan port)-SXR -(LAN port)--->Switch----satellites?
Although I tried with LAN port in SXR as well but same results.
