lostgear
Mar 20, 2023Star
Orbi Pro Mini showing unattached wired (directly) devices as Attached Devices: Normal?
My setup: Router<--->managed switch <----> Orbi Pro Mini (AP) mode Under Wired Attached Devices, it is showing devices connected to the managed switch (i.e not directly connected to the LAN p...
Mar 20, 2023Guru - Experienced User
In the last post you didn't have it wired right either.
Things aren't going to show up properly when wired wrong.
gateway/modem----wan port on SXR---lan port---->switch----->satellites/devices
And if the switch is handling dhcp and you want it before the orbi, the satellites need be connected to the lan port if using the wired backhaul. Not through the switch
