rdmccarty
Jul 03, 2025Aspirant
Orbi Pro Orbi 6 (SXR80 - SXS80) Satellites won't connect
I have a Orbi Pro router that came paired with 2 satellites. I have had it for 4 years and recently if I have a power outage, like we have in OK often, my 2 satellites disconnect from the router and ...
abdsea
Nov 01, 2025Guide
I am curious, do you happen to have more than 2 wireless LAN? I notice lots of weirdness if you have more than 2 wireless LAN. if you do, try turning off the 3rd one and it will immediately sync. You can turn it back on afterwards ... don't ask me why :-)
