Beneficia
Jan 22, 2026Aspirant
Orbi Pro Router (SXR80) Satellite Connection Issues (SXS80)
I have been running two networks based on the SXR80 router and SXS80 satellites. Recently I have been seeing a strange behavior. The Insight App and Cloud say the satellites are NOT connected, but t...
Beneficia
I know it is strange and it came on out of nowhere with the same firmware. I was thinking the same thing about a factory reset and was a paperclip away from doing it, but I could not bear the thought of fighting through that when I have connectivity and preoccupied with other things. It still seems like it is worth a try when I have time.
Definitely frustrating because I have two routers on two networks and 9 satellites, so I have dropped a lot of money on these systems. : (
Thanks for the thoughts!
Jan 22, 2026Guru - Experienced User
Save backup configs to file. Saves time if a FR is needed.
