alayman
Jan 02, 2018Aspirant
Orbi Pro satellite doesn't go quite far enough - add another satellite or wireless AP?
My house is on a fairly large property. I installed a new Orbi Pro SRK60 router and satellite and it works quite well inside the house. I have the satellite sitting on a window sill that faces dire...
alayman
Jan 04, 2018Aspirant
I like that idea as well, but it would mean that the new satellite would connect to the existing satellite. I thought each satellite needed to connect to the router. Assuming the satellites can connect to each other, is there any special setup necessary or do I just do it like I did the first satellite - which was very easy by the way...
Thanks!
JohnC_V
Jan 04, 2018NETGEAR Employee Retired
Yes, you are correct. Orbi Pro only supports the connection from satellite to router. It has the same way of adding satellite like the first one.
- alaymanJan 04, 2018Aspirant
Ok, but that means that the original response is incorrect. Whatever I buy new needs to be able to connect to the exisitng satellite. Based on your last response, that is not possible. So the only solution is to purchase a wireless AP?
- JohnC_VJan 05, 2018NETGEAR Employee Retired
My apologies for the confusion. You may still purchase a satellite and sync it with the router, but you have to swap the locations of those devices. If you will be purchasing a wireless AP, you may need to hard wire it as it cannot be synced with your previous setup.
- JohnC_VJan 08, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- alaymanJan 08, 2018Aspirant
I can't swap the router and the current satellite locations because of the location of my cable connection. So, unless I can get the satellites to talk to one another, I guess I will have to try the wireless AP.
