alayman's avatar
alayman
Orbi Pro satellite doesn't go quite far enough - add another satellite or wireless AP?
My house is on a fairly large property.  I installed a new Orbi Pro SRK60 router and satellite and it works quite well inside the house.  I have the satellite sitting on a window sill that faces dire...
  • JohnC_V's avatar
    JohnC_V
    Jan 09, 2018
    alayman,
    As per inquiring the case that you have, you may purchase our outdoor satellite which pairs with Orbi Pro Router and Satellite.
    Please check RBS50Y.
ProSupport for Business
