serbes's avatar
serbes
Tutor
Oct 25, 2020
orbi pro srk 60
Hello,
I have a wifi installation in a school (orbi pro srk 60 with 9 SRS60)
New users regularly do not know how to connect due to lack of ip address
This problem happens around 60 users are logged in
I assume that the movement of inbound and outbound users saturates the available ip addresses
How can we increase the number of IP address of the DHCP domain or other solutions?
Solution via Insight application or connection by PC on the local network
Thank you in advance for your reactions and answers
Serbes Ali
  • Out of the box, the SRR60 does max out the possible IP subnet address range with 192.168.1.2 to 192.168.1.254, see ADVANCED > Setup > LAN Setup.
    One thing that hits my eye is the set-up with router plus nine satellites - AFAIK the max number of satellites supported is six. Are your satellites on a wired backhaul or is this a completely wireless set-up?
  • schumaku's avatar
    schumaku
    • serbes's avatar
      serbes
      Tutor
      Thank for your quickly answer,
      Thank you for your prompt response
      Indeed the range of addresses varies from 192.168.1.2 to 192.168.1.254 by default
      Can we increase beyond that?
      Or get the addresses of users leaving the network quickly?
      Thank you in advance for more
      Serbes Ali
ProSupport for Business
