rolandvaneijk
Jun 30, 2021Aspirant
Orbi Pro SRK60 and GS316 wired backhaul sync problems
To improve coverage I have changed the network setup from: ISP modem -> SRR60 (Orbi router) -> SRS60 (Orbi satellite, via SRR60 port 2) and GS316 (16-port unmanaged switch, via SRR60 port 3) To: ...
- Jun 30, 2021
- ISP modem -> SRR60 (Orbi router) -> SRS60 (Orbi satellite, via SRR60 port 2) and GS316 (16-port unmanaged switch, via SRR60 port 3)
To:
- ISP modem -> GS316 -> SRR60 (via GS316 port 2) and SRS60 (via GS316 port 3)
Is the new network setup usable?
No, it's not useable at all - you are mixing two networks, one is your ISP Internet, the other is your local network.
The ISP Modem must be a diect link/cable to the Orbi SRR60 WAN/Internet port only. Nothing else is possible (unless you head to operate VLAN capable switches and configure accordingly to be two networks, two VLAN, no mix.
Back to the original set-up.
rolandvaneijk
It’s a Netgear switch. Should be compatible I may hope.
Another question: Does it matter that the ISP signal leads to the Orbi router (SRR60) via the switch?
The solution you describe is my old setup. Unfortunately that setup implies having the Orbi router on a suboptimal position for wireless coverage.
Jun 30, 2021Guru - Experienced User
Hopefully however something to test out to be sure. Seen odd things with switches and any green ethernet features. Though NG did say Pro Series is compatible with Green Ethernet. So something to test out. Possible the switch could be faulty as well.
Standard connection and networking practices have any NAT router connected directly to ISP Modem/ONT devices. No switch in between. Puttin a switch can cause some problems or inconsistent connects, or performance problems.
The use of a longer LAN cable can be used if needed between the ISP services devices and the Orbi router to help to keep with same location for the Orbi router.
