Marco-F
Feb 13, 2020Aspirant
Orbi Pro SRK60 not mentioned in daisy-chain support article
I understtod that since a copule of years the Orbi Pro family, including the model SRK60, does support daisy-chain or connection of the units through Ethernet cable, swtiches. Nevertheless this a...
- Feb 16, 2020
Way back January 2018, Orbi Pro firmware v2.1.2.18 was officially released and Daisy-Chain Topology is one of its new features and enhancements. As reference, kindly check it here.
Currently, the latest Orbi Pro firmware is v2.5.1.106 and it still supports Daisy-Chain Topology. You can download it here.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
schumaku
Feb 15, 2020Guru - Experienced User
Orbi Pro comes from a different business unit.
Marco-F wrote:I understtod that since a copule of years the Orbi Pro family, including the model SRK60, does support daisy-chain or connection of the units through Ethernet cable, swtiches.
Non-managed switches, switches without Spanning Tree Protocol (STP), ... yes.
