DJHazmat
Mar 01, 2021Star
Orbi Pro SRK60 V.2.6.0.108 is blocking Genie Aladdin Wifi Garage connection
Hey Guys, I am using the SRR60 in AP mode and have been for almost 2 years. Everything worked fine with My Aladdin garage door wifi system being connected to it. I just upgraded to firmware V2.6.0.10...
- Mar 11, 2021
I was able to get the beta firmware 2.6.2.200 and install it. I haven't had much time to test anything else, but the issue I was having with the Genie Aladdin garage door opener is resolved. I think it was DNS because it was not able to connect to the internet. Other reports here indicate that the 2.6.0.108 firmware had changed DNS relay to the internet and the beta fw corrected that.
Another by-product of the firmware that I noticed is that the Orbi mobile App now works again. You can see the network map, the device list, and reboot the router from there.
I am guessing the firmware will be released soon.
