cristmo
Oct 27, 2021Aspirant
Orbi Pro SRR60 Router - unable to connect to Orbi App
I have the Orbi Pro SRR60 router with two satellites attached. The netire network is working fine except for 1 thing. I can't get the Orbi App to recognize my router. I was able to initially but a...
- Oct 28, 2021
The firmware upgrade did the trick. As soon as I did that and logged back into the Orbi App, my router and network were immediately recognized and I can manage the network from the App. THANK YOU!
Oct 27, 2021Guru - Experienced User
Orbi Pro systems only support the InSight app. No Orbi app. Orbi app is for Orbi AC and AX systems.
Does InSight app connect to your Orbi Pro?
- cristmoOct 27, 2021Aspirant
Firmware version: V2.6.0.108
- RaghuHROct 27, 2021NETGEAR Expert
cristmo please upgrade to the latest firmware. https://www.netgear.com/support/product/SRR60.aspx#SRR60%20(Orbi%20Pro%20Router)%20Firmware%20Version%202.7.0.122
- cristmoOct 28, 2021Aspirant
Thank you for the suggestion to upgrade. I will do that this weekend while everyone is off the network.
