whartonw
Mar 13, 2021Guide
Orbi Pro SRR66 Loses Wired Connections & Firmware Update
I am experiencing a great example of the typical problems with Netgear software. The INSIGHT mobile app says there's a firmware update available for my router, but it also says that the update ca...
MrJoshW
Mar 15, 2021NETGEAR Employee Retired
Hello,
In regards to the new firmware reported on Insight. What firmware version does it show that is available to download? What firmware version is the SRR60 currently on?
whartonw
Mar 15, 2021Guide
MrJoshW wrote:Hello,
Thanks, JoshW, for your reply.
The firmware was 2.4.2.106. The update was applied overnight that night, as scheduled, to 2.6.2.200. This update did not solve the dropped wired connections, however, so I replaced router with a new unit today, which also has no wired connections!
