JDWillmore
Feb 11, 2022Aspirant
Orbi Pro SXK30 guest splash page never launches
Orbi Pro WiFi 6 Mini AX1800 Mesh System FW = V4.0.1.100 Everything has been left as defult except the three SSID's I created. Enabled Guest Portal Network Enabled SSID Broadcast VLAN profi...
Feb 14, 2022Guru - Experienced User
What iOS is on the Apple devices?
Have you tried disabling WiFi Private Address on the apple devices then try the guest network page?
- JDWillmoreFeb 15, 2022AspirantI’m using 15.3.1 on iOS
I had not tried disabling private wifi but the same process still happens. Connects to router but then says no internet connection.
Thanks for the help. Any other info I can send your way?
