JDWillmore
Feb 11, 2022Aspirant
Orbi Pro SXK30 guest splash page never launches
Orbi Pro WiFi 6 Mini AX1800 Mesh System FW = V4.0.1.100 Everything has been left as defult except the three SSID's I created. Enabled Guest Portal Network Enabled SSID Broadcast VLAN profi...
Feb 14, 2022Guru - Experienced User
What iOS is on the Apple devices?
Have you tried disabling WiFi Private Address on the apple devices then try the guest network page?
JDWillmore
Feb 15, 2022Aspirant
I’m using 15.3.1 on iOS
I had not tried disabling private wifi but the same process still happens. Connects to router but then says no internet connection.
Thanks for the help. Any other info I can send your way?
