JDWillmore
Feb 11, 2022Aspirant
Orbi Pro SXK30 guest splash page never launches
Orbi Pro WiFi 6 Mini AX1800 Mesh System FW = V4.0.1.100 Everything has been left as defult except the three SSID's I created. Enabled Guest Portal Network Enabled SSID Broadcast VLAN profi...
PossetBoy
Feb 25, 2022Initiate
You are not alone, I have the same issue. My current setup is very similar to yours.
Orbi Pro WiFi 6 Mini Mesh System
FW = V4.0.1.100
VLAN profile Guest 40.
authentiation Mode = local
Password authentication = entered a password
Expiration 2 hours
uploaded my own logo at 200 x 200 ; but default logo also has the same issue
no redirected URL.
My installation is in a small public building with many of users. Apple products do not seem to work; but all types of Android and Windows devices are fine, and can see the logo, and login successfully. To me, this looks like an Apple security issue with the Guest network. I need a short term fix, so I'm using one of the other wireless networks as a Guest network, but without the logo and timeout features. I too would like a fix for this issue.
DavidGo
Feb 28, 2022NETGEAR Expert
Hi JDWillmore , PossetBoy ,
Our engineering team are aware of the issue and working on a fix, a beta firmware should be available next week. Once the firmware is ready I will reach out via PM to get beta NDA agreement and provide download link.
Regards
DavidGo
- BrainSuperGlueMar 28, 2022Tutor
Hi DavidGo ,
Can I get a copy of the beta firmware for the SXR30 Mini, that fixes the issue with iOS devices trying to connect to the Guest Portal, and not being redirected to the Captive Portal page to enter the guest password.
Currently on latest FW : V4.0.1.100
iOS version 15.4 (19E241)
Thanks- DavidGoMar 29, 2022NETGEAR Expert
Hi BrainSuperGlue , JDWillmore , PossetBoy
The beta is available at [In Beta] SXK30/50/80 Beta Firmware Version 4.2.0.122
- [SXK30] Fixes guest portal sometime doesn’t pop-up
Please let me know if you encounter any issues.
Thanks
DavidGo
- BrainSuperGlueMar 29, 2022Tutor
Hi DavidGo ,
I'm logged into Netgear Community, I've tried three different browsers but keep getting Access Denied for that link for the beta.
https://community.netgear.com/t5/Orbi-Pro-Beta/In-Beta-SXK30-50-80-Beta-Firmware-Version-4-2-0-122/m-p/2208795#M49
Please can you fix any access permissions to the beta.
Thanks
