Filis
Oct 16, 2021Aspirant
Orbi pro (SXK80) behind UDM router | Dynamic Vlan via radius
Dear community, dear Netgear Team, I set up a UniFi UDM as a router with a radius server. Behind the UDM, I am running a Orbi Pro (SXK80 and a SXS80) on firmware 3.3.0.122 as an AP. The challenge...
Filis
Oct 17, 2021Aspirant
The tcpdump
21:46:58.681381 IP (tos 0x0, ttl 64, id 53332, offset 0, flags [none], proto UDP (17), length 221)
[ip address router].1812 > [ip address SXK80].44930: [udp sum ok] RADIUS, length: 193
Access-Accept (2), id: 0x17, Authenticator: [mac address]
Acct-Interim-Interval Attribute (85), length: 6, Value: 01:00:00 hours
0x0000: 0000 0e10
Tunnel-Type Attribute (64), length: 6, Value: Tag[Unused] VLAN
0x0000: 0000 000d
Tunnel-Medium-Type Attribute (65), length: 6, Value: Tag[Unused] 802
0x0000: 0000 0006
Tunnel-Private-Group-ID Attribute (81), length: 4, Value: 30
0x0000: 3330
User-Name Attribute (1), length: 11, Value: users
0x0000: [digits]
Vendor-Specific Attribute (26), length: 58, Value: Vendor: Microsoft (311)
Vendor Attribute: 17, Length: 50, Value: ..&...P...I..o.nd.^e.U...k1.d.[an..@lQ.........C..
0x0000: [8 blocks of 4 digits]
0x0010: [8 blocks of 4 digits]
0x0020: [8 blocks of 4 digits]
0x0030: [4 blocks of 4 digits]
- schumakuOct 17, 2021Guru - Experienced User
- FilisOct 19, 2021Aspirant
Thank you, schumaku.
I was hoping there is an option to do something like this with the UDM as a router and OrbiPro (SKX80) as a wifi access point?
https://www.downloads.netgear.com/files/answers/Dynamic%20VLAN%20Assignment%20using%20RADIUS.pdf
https://www.youtube.com/watch?v=l2ivHDIV50g
https://www.youtube.com/watch?v=AJcKsGtyfHo
- BruceGuoOct 20, 2021NETGEAR Expert
Thanks for sharing your opinion. I know the feature. I will check with internal teams if we can do it and what's the plan.
