BIG9MM
May 13, 2021Apprentice
Orbi Pro SXK80 missing Daisy Chain?
I do not see Daisy Chain in the settings on the Orbi Pro SXK80,
Is it removed or does it still work?
Thanks!
BIG9MM wrote:Very interesting. I’m actually running both of the Orbi Pro, Older unit, and a new unit. Older unit still has it, and newer unit I do not see it.it's not about old or new - the classic Orbi Pro has the daisy chain control (just like the legacy consumer Orbi systems), while Orbi Pro WiFi 6 does apparently not require a manual control.
We were told several times the new Orbi Pro WiFi 6 system "does it right automatically". I'm not convinced this is true for all possible combination of wired and wireless backhauls however...
- JohnD333ApprenticeI have the same issue. 3 satellites plus base. All satellites connect to base. Despite a sat placed half way in between providing a much stronger/closer signal via windows, most distant sat goes all the way to base through 3 concrete walls. Results in “fair” signal and All devices attached have crap for speed. Still waiting for firmware to address this.
- BIG9MMApprenticeVery interesting. I’m actually running both of the Orbi Pro, Older unit, and a new unit. Older unit still has it, and newer unit I do not see it. I hope one of the tech-support see this post and try to put somehow a way that we can see how all the satellites are daisychained similar to the home version . TThanks for your response!
JohnD333 wrote:
I have the same issue. 3 satellites plus base. All satellites connect to base. Despite a sat placed half way in between providing a much stronger/closer signal via windows, most distant sat goes all the way to base through 3 concrete walls. Results in “fair” signal and All devices attached have crap for speed. Still waiting for firmware to address this.- schumakuGuru - Experienced User
