WonKim's avatar
WonKim
ORBI PRO SXK80B4 Flow Internet
Hi, can everyone tell me, please one question that worry me.
My newly bought Orbi Pro SXK80B4 with 4 satellits can not connect fast to the Intel AC Wireless AX210 card.
The router is in the same room in 1 feet from a PC and only show me 1200Mbits and not 2400Mbits that could do my Orbi Pro according to the description (2400+2400+1200). Why It doesnt use 160Mhz wave leight. I bet It connect to the Intel AX210 adaptor via 80Mhz wave. I searched everything and did not finde any manner to chose the speed of the AX connection.
How can I connect my laptop to 2400mbits, please?
And the second, on the site was announced free 1 year insight use. But in reality the system gave me only 30 days trial, and not 1 year!!!
Notifying me every day of the proximate end of that period. Any posiibility to fix and give me what was announced?
  • a couple things.
    1. the is the community support forum. where members of the public help out. If you're having insight issues, I'd contact actual netgear support.
    2. the SXK80 supports 2400mbps over a 4x4 antenna setup with 80hz wide channels on the fronthaul 5ghz. It doesn't support 160hz wide channels.
    3. The intel AX210 is a 2x2 antenna setup that'll connect at 2400mbps IF you're using 160hz wide channels. The best it'll achieve on a 80hz wide channel is 1200mbps. You'd need a 4x4 wireless card to hit 2400mbps. So you're not going to hit 2400mbps on that router/card setup.
  • plemans's avatar
    a couple things.
    • WonKim's avatar
      WonKim
      Thanks for aclaration. Noone mention in any part that  SXK80 supports only 2400mbps over a 4x4 antenna.
      Only one single drop of info I founded that It is 4x4 MIMO. And absolutelly nothing that it is limited with 80hz. If I knew I would newer buy It.
      Lyish marketing of Netgear. Why not to open all specification to let me know what exactly they are selling to got what I really need.
      Of course for consummers and business users no prestent 4x4 MIMO devices and they will not appear in the near and far future.
      What was stopping them to make 160Hz wide channels and make it 2x2 MIMO intead of 4x4, knowing that noone can use 4x4?
      P.S.
      With the device I can use my oldie MacMini 2018 with 3x3 MIMO WiFi5 AC 1300Mbit speed over 5Hz and 80Hz channels.
      That wasn't the case because I planned my WiFi6 network without looking back to 2018.
      • plemans's avatar
        I'd agree they don't do the best in advertising the its only a 20/40/80hz device and doesn't support 160hz.
        It makes it a bit of a challenge. Its the same with the consumer Orbi AX. I think with testing, there wasn't much speed difference seen between the 2 because of distance and radio interference at 160hz wide. The connection link drops off rapidly so they benefit wasn't there.
        I dont' have one and wasn't in on any testing so I can't confirm that.
        I know I have an Arris W31 AX11000 which supports 160hz between the router and satellite and I don't see much difference in speed from the satellite. And that's comparing with my older RBK53 system.
ProSupport for Business
