ColdFire3000
Jun 06, 2022Aspirant
Orbi Pro SXR30 SXS30 wired backhaul
I have a brand new Orbi setup and having nothing but issues with it. My setup is: Downstairs Virgin router->switch with SXR 30 plugged into it Switch->cat5 cable through ceiling to middle floor ...
- Jun 08, 2022I didn't do anything differently in terms of config, except that I did it all using the web interface rather than the stupid app.
This time everything worked the way it was supposed to.
I've got all the cabling setup exactly the same way. Although in testing the wireless backhaul is actually working quite well, so might leave it wireless for easier locating.
As promised, the attached images show the satellite connected via wireless Vs wired backhaul between the router and the satellite. Note that the wireless part being lit up or not. I've not seen this information clearly shown with screenshots anywhere, only in the Orbi app, so hopefully it's helpful to someone!
ColdFire3000
Jun 07, 2022Aspirant
The setup is as per diagram 3 in the link, but with an extra switch between the router and the SXS. But as I said, I have the same issue with a direct connection to the router it seems, so the switches are not relevant really.
ColdFire3000
Diagram of how I would like it setup
- RaghuHRJun 07, 2022NETGEAR Expert
Hi ColdFire3000 Thanks for the network diagram. This makes more clear. We are tracking your issue internally. Will reach out to you if we need more info. Have a good day!
Raghu
- FURRYe38Jun 07, 2022Guru - Experienced User
What FW version do you have loaded?
That's how I have mine setup. Though I have GS105s at the Middle and Loft areas for my house.
Working well when I had it online. CAT6A in wall. CAT6 patch cables.
- ColdFire3000Jun 07, 2022Aspirant
Good to know I am not insane then!
FW is 4.2.0.122
If you have a minute, can you please confirm any of the following?
1. Did you have the SXR/SXS30 or another model?
2. Did you use a specific port on the units for the backhaul? I have seen mention this is required, but seems odd and I am using the 1st port anyway, which seemed to be the requirement.
3. Did you use the regular Orbi app or the Insight app?
4. Do you know how to confirm that wired backhaul is 100% being used?
I won't have another chance to disconnect my existing setup and play around until Thursday, so trying to get as much info as possible before then. If they are not working fully by the weekend then I am just going to return them and get a cheap Unifi AP to add to my existing!
Thanks
FW is 4.2.0.122
1. Did you have the SXR/SXS30 or another model? I have the SXK30 which includes a SXR and 1 SXS. I actually had two systems but sent one to a buddy of mine. FarmerBob1
2. Did you use a specific port on the units for the backhaul? I have seen mention this is required, but seems odd and I am using the 1st port anyway, which seemed to be the requirement. No, I believe I used port #2 out from the SXR to the 1st switch GS108. I keep port #1 for my HP pro curve home 24 port switch most of the time.
3. Did you use the regular Orbi app or the Insight app? I used the SXR web page to setup the SXR first I had the SXS already staged in the basement and connected to the GS105 switch there. SXS was turned OFF until I got the SXR fully setup. Then I turned ON the SXS and it eventually connected. I had mine running for 3+ days with no problems before putting my 9 series online for other testing.
4. Do you know how to confirm that wired backhaul is 100% being used? Look at the SXRs web page on Connected Devices. SXS will how wired instead of wireless. You can look at the SXS web page as well and the WiFi graphic that would normally be enabled should be grayed out. This signifies that the SXS is using ethernet backhaul.
