ecolive's avatar
ecolive
Initiate
Mar 19, 2024
Orbi Pro SXR80 failed - red light even after HW reset on a known good connection
This router has 5 yr HW support, good until 2027. It failed today from one second to another. Checked internet modem connection with another router (good conn) and did a zHW reset on the Orbi Pro. Trying to contact support but all channels (chat, phone, online) indicate “expired”. How can one get a replacement router for a failing router still under warranty? Thanks. .
1 Reply
  • schumaku's avatar
    schumaku
    The SXR80 was released around April 2020, so yes - well within the five years limited warranty.
    When you head to https://my.netgear.com/ after login, click on the SXR80 on the list of registered products, and you will find this:
    Serial Number: 1234567890123
    Registered on: yyyy-mm-dd
    Purchased: yyyy-mm-dd
    I would expect to see something like this where you can choose: [Request Hardware Support]
    So if you are the first owner, have a proof of ownership, and have purchased from a NETGEAR authorized reseller - this should be possible.
    This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller.
    190-day complimentary technical support following purchase from a NETGEAR authorized reseller.
    2Some features may require an Insight Premium service subscription.
    3The NETGEAR OnCall 24x7 contract provides unlimited phone, chat and email technical support for your networking product.
    4 Enabled by a future firmware update.
    For regulatory compliance information, visit http://www.NETGEAR.com/about/regulatory
ProSupport for Business
