rdhull's avatar
rdhull
SXR80 Firmware 4.0.0.118 Update Fails on Satellite
Trying to update SXR80 firmware from V3.0.0.208 to V4.0.0.118.
I tried automatic update, and the router downloaded the update, but did not apply it. Satellite did not download. So I went manual.
Manual upload of firmware to router worked fine, and router updated, but Satellite did not. Every time I try, Satellite reports:
"This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
But it is the same firmware file I used to update the router, which worked just fine.
Guidance appreciated!
David
ProSupport for Business
