mldcmx
Apr 19, 2021Follower
Orbi Pro Tri-Band Wi-Fi 6 AX6000 (SXK80) Processor Speed?
My question is, what are the processor specs (# of cores and GHz speed) for the Orbi Pro Tri-Band Wi-Fi 6 AX6000 (SXK80)?
I'm looking between two products to purchase for a small business. One being the product I'm asking about, the other being the home solution Orbi AX6000 (RBK85). The home solution gives me the specs for the processor (Quad-Core 2.2GHz) but the business solution doesn't. Wondering if both products are identical in hardware, but not in software. I looked at the post below for answers, but some of the points were confusing.
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/RBK852-Vs-SXK80/m-p/1971392
Thanks for your time!
Welcome to our community! :)
As per our L3 engineers, both products have the same Quad-Core 2.2GHz processor. If it is for small businesses, I suggest you get the Orbi Pro as it does support VLAN and for future-proofing too just in case you expand your business.
John
NETGEAR Community Team
1 Reply
- JohnC_VNETGEAR Employee Retired
John
