ThePathfinder's avatar
ThePathfinder
Apprentice
Sep 05, 2017
ORBI PRO vs RBK53
Please detail the differences between the new ORBI Pro vs the RBK53, also will the Pro have its own firmware or will it rely on the same firmware as the RBK53?   Thanks
  • DaneA's avatar
    DaneA
    Oct 02, 2017
    Hi nbac6s7,
    Welcome to the community! :)
    Here below are the features supported by the Orbi Pro:
    1. Default AP mode - Unlike the Orbi Home Routers, the Orbi Pro router will be set to the “Access Point Mode” even if an existing router is
    detected or not.  You can set the Orbi Pro router on "Router Mode" manually.  The following functions are supported when the Orbi Pro router is set to Router Mode:
    • Access control
    • Traffic meter
    • Block sites
    • Block service
    • Static route
    • Port forwarding
    • Port triggering
    • IPv6
    • UPnP
    • Remote management
    • VPN Service
    2. Multiple SSIDs - The Orbi Pro supports three isolated wireless networks. The devices on different SSIDs cannot communicate with each other.  This feature is available on both Router Mode and AP mode.
    3. Guest Network with Captive Portal
    Kindly read the following article for more information:
    What advanced features does my Orbi Pro WiFi System support?
    How many square feet does my Orbi Pro cover?
    DaneA
    NETGEAR Community Team
ProSupport for Business
