wmh1968
Apr 23, 2023Tutor
ORBI PRO WIFI 6 SXK30100NAS
I just purchased an NETGEAR ORBI PRO WIFI 6 SXK30100NAS at MicroCenter for $300. I'm googling for info on setup and use and I don't find anything anywhere near that price. Either was below or way abo...
- Apr 28, 2023
Click on advanced and it should give you an option to let you proceed.
You can always factory reset the router to clear out everything and start over.
Or if you mean on your device, there's usually a forget network option.
wmh1968
Apr 28, 2023Tutor
Well, I finally got the netGear Orbi Pro working on our 2 phones and one of my laptops. I left att wifi on. I could not get my 2nd laptop to work on Orbi and was trying all kinds of thing and messed something up. I would like to start from scratch. How do U do that with my cells and laptops?I get this when I try yo go to alot of websites
Apr 28, 2023Guru - Experienced User
- wmh1968Apr 28, 2023Tutor
Thanks, I reset Orbi and started new and so far everything is great. Thanks, Mike
