rroesch
Nov 11, 2020Aspirant
Orbi RBS50Y Will Not Connect
Nov 11, 2020Guru - Experienced User
Solid white usually indicates its booted and ready to sync. Pulsing white usually means its booting.
Pulsing blue is booting/changing to extender mode. Solid blue means its ready to sync.
Try changing its modes maybe the firmware for extender mode works fine. It'd at least let you get it booted and maybe update firmware.
https://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_QSG_EN.pdf
rroesch
Holding synch button while powering on.... Pulses white, never blue, then goes to solid white. Basically no change.
