IanPhillips's avatar
IanPhillips
Problems connecting RBS50Y
I am trying to install an RBS50Y Outdoor Orbi as a satellite to my house system.
I successfully set up the RBS50Y - connected to my base station (an RBR40) no problem (Installed as an "Add-on Satellite"
I installed the new RBS50Y in my garage and powered it on.  After booting the light shows solid blue suggesting the device is connected to my network.  Whilst in the garage I am able to see the RBS50Y on my phones wifi list, and can connect OK - but there is no internet connection.
I checked on my Orbi app - the RBS50Y shows up - indicating there is some connection as it would not be there if powered off - but is not "connected".
I logged onto the router via http://orbilogin.com - and the RBS50Y shows as disconnected.  Daisy chain is enabled.
I have three other satellites on my Orbi network - two RBS40's and an RBS20 - all working well.
The RBS20 is indoors and is the closest device to the RBS50Y in my garage (distance around 10 meters / 30ft).
Any suggestions on what might be wrong here - and how I might be able to use my RBS50Y for teh outside wifi it wa smeant to provide
Any and all ideas much appreciated.
  • Thanks for your suggestions
    Tried all of this and got nowhere
    Eventually had to go through the pain of a factory reset on my entire system  and eventually figured out that the RBS50Y had switched into "range extender" mode rather than default Orbi mode - doing thsi requires some serious effort and I dont think I did it . but hey ho.
    Sytem now rebuilt and RBS50Y working OK - although the distance to my garage (plus a couple of solid walls) makes the backhaul connection "poor" on a 2.4GH connection.
    Appreciate your suggestions
  • FURRYe38's avatar
    What Firmware version is currently loaded on the RBR and RBSY?
    Can you access the RBSYs web page with a PC and web browser?
    YOu might turn OFF the other RBS and power cycle the RBSY and see if it gets connected and appears as connected in the RBRs web page.
    • IanPhillips's avatar
      IanPhillips
