Theo_C
Jul 06, 2023Tutor
Orbi router SXR80 + 5 satellites SXS80 in ethernet backhaul not working properly
Hello all, we are using the Orbi router SXR80 in backhaul with 5 satellites SXS80, all satellites are correctly recognized in wired mode, but for 2 of these 5 satellites, no devices seem to be able t...
BruceGuo
Jul 07, 2023NETGEAR Expert
Hi
I don't see the limitation. Can you draw your topology and our SW team will reproduce the issue. See if you can provide debug files so that we can import your configuration.
Bruce
NETGEAR
Theo_C
Jul 07, 2023Tutor
Here is the topology, RED satellites are seen by the router as wired but no equipment can connect to them, GREEN satellites are also seen by the router and equipement can connect to them. Devices can also connect to the router in AP mode.
I don't really have any logs to give you, the satellites don't have any, and those from the router in AP mode aren't interesting.
But here are two screenshots to show you that there's no equipment on it.
