Theo_C
Jul 06, 2023Tutor
Orbi router SXR80 + 5 satellites SXS80 in ethernet backhaul not working properly
Hello all, we are using the Orbi router SXR80 in backhaul with 5 satellites SXS80, all satellites are correctly recognized in wired mode, but for 2 of these 5 satellites, no devices seem to be able t...
Jul 07, 2023Guru - Experienced User
curious if its a satellite specific issue or a location issue.
Can you swap one not connecting with one that is and see if anything changes?
Theo_C
Jul 07, 2023Tutor
Yes, I could, but what's annoying is that I'm in a company, and I can't carry out my tests during working hours, because every time a satellite is synchronized, all the wifi goes down. I've tried changing my satellite postions, but unfortunately it's not better.
- plemansJul 07, 2023Guru - Experienced User
with your topology, have you tried going:
1st switch---->SXR wan port----lan port out----->2nd switch----->sxs?
that way the switch is off the SXR's lan ports
