Theo_C
Jul 06, 2023Tutor
Orbi router SXR80 + 5 satellites SXS80 in ethernet backhaul not working properly
Hello all, we are using the Orbi router SXR80 in backhaul with 5 satellites SXS80, all satellites are correctly recognized in wired mode, but for 2 of these 5 satellites, no devices seem to be able t...
Theo_C
Jul 19, 2023Tutor
I captured and saved the debug logs, I sent you a private message 🙂
Thanks again for your help!
Theo_C
Jul 20, 2023Tutor
Hello all,
I think I've found the problem, looking at the basic_debug_log.txt file, I can see that my STAFF SSID is missing on my satellite-4, the GUEST SSID appears but not the STAFF one, although the ports on my switch and on the satellite are in trunk mode.
And indeed, when I'm next to the satellite, I can connect to the GUEST network, but not STAFF.
Do you have any ideas?
