tomnorris1967
May 26, 2020Aspirant
Orbi srk 60
Can the satellites be placed outdoors?
- May 27, 2020
Welcome to the community! :)
The applicable satellite to be placed outdoors that is compatible to work with the Orbi Pro WiFi System is the RBS50Y. As per the RBS50Y data sheet here, it is required to have the Orbi Pro router (SRR60) to sync the RBS50Y Orbi Add-on Outdoor Satellite.
Be sure to upload the appropriate RBS50Y firmware since you will sync the RBS50Y to the Orbi Pro. The latest RBS50Y firmware version for Orbi Pro is v2.5.2.104 and you can download it here.
To learn more, kindly access the link below:
Add-on Orbi Outdoor Satellite (RBS50Y)
DaneA
NETGEAR Community Team
DaneA
May 27, 2020NETGEAR Employee Retired
DaneA
- tomnorris1967May 27, 2020Aspirant
Thank you
- DaneAMay 28, 2020NETGEAR Employee Retired
You're welcome! :)
Since your concern has been addressed, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
