tomnorris1967's avatar
May 26, 2020
Orbi srk 60
Can the satellites be placed outdoors?
  • DaneA's avatar
    May 27, 2020
    tomnorris1967,
    Welcome to the community! :)
    The applicable satellite to be placed outdoors that is compatible to work with the Orbi Pro WiFi System is the RBS50Y.   As per the RBS50Y data sheet here, it is required to have the Orbi Pro router (SRR60) to sync the RBS50Y Orbi Add-on Outdoor Satellite.
    Be sure to upload the appropriate RBS50Y firmware since you will sync the RBS50Y to the Orbi Pro.  The latest RBS50Y firmware version for Orbi Pro is v2.5.2.104 and you can download it here
    To learn more, kindly access the link below:
    Add-on Orbi Outdoor Satellite (RBS50Y)
    DaneA
    NETGEAR Community Team
ProSupport for Business
