Robbie7
Jul 09, 2021Follower
Orbi SRR60 Guest Portal Stuck
When guests try and login to guest wifi, the portal loads and asks for them to agree to terms. After hitting agree the page reloads back to itself. This used to work perfectly and re-direct to a webs...
DaneA
Jul 11, 2021NETGEAR Employee Retired
Welcome to the community! :)
Since everything was working fine before, are there any recent changes done on the settings of the SRR60 that might have triggered the problem?
What is the current firmware version of the SRR60?
DaneA
NETGEAR Community Team
