Mu-5
Jan 23, 2023Follower
Orbi5XR30 Which code is Security Code on bottom label. Tried them all so, Trying to connect laptop.
CrimpOn
Jan 23, 2023Guru - Experienced User
The product label on my Orbi (different model) contains:
WiFi Network Name (SSID) which is the letters "ORBI" plus a two digit number, and
Network Key (Password), which is a couple of random words, such as "monstermonkey"
There is also a QR code, which I ignore.
This is not what your product label shows?
CrimpOn
During the product setup, many users decide to change both the SSID and the password to something else. For example, every WiFi router I have installed since 2005 has had exactly the same SSID/password. If this was done, then the product label no longer applies.
- michaelkenwardJan 24, 2023Guru - Experienced User
A reset will restore those details to the default.
You can then change them to whatever takes your fancy. Just remember to remember them.
