Mu-5
Jan 23, 2023Follower
Orbi5XR30 Which code is Security Code on bottom label. Tried them all so, Trying to connect laptop.
CrimpOn
Jan 23, 2023Guru - Experienced User
During the product setup, many users decide to change both the SSID and the password to something else. For example, every WiFi router I have installed since 2005 has had exactly the same SSID/password. If this was done, then the product label no longer applies.
michaelkenward
Jan 24, 2023Guru - Experienced User
A reset will restore those details to the default.
You can then change them to whatever takes your fancy. Just remember to remember them.
