Garyricks
Aug 10, 2022Aspirant
Orbiguest network wont dissappear
I Have An Orbi-Guest Network That Is showing, that I Cant Get To Gonaway. I Have Done Everything . I Have Reset The SatellIte And The Router. I Have Shut Them Down And Its Still There. WheN I Check ...
CrimpOn
Aug 10, 2022Guru - Experienced User
Does this mean what it appears to mean? i.e. The Orbi router and satellite have been powered off, yet devices continue to report that a WiFi network called (what exactly?) is still available?
It is an amazing WiFi access point that can broadcast a signal when there is no power.
michaelkenward
Aug 18, 2022Guru - Experienced User
It could happen if the neighbours also have an Orbi system. Hard to tell from the details provided.
- GaryricksAug 18, 2022Aspirant
Possible, I have considered that. I do recall though, we were having issues getting it set up (small business) and I had changed the name to what we have it now, we could not get it so we were reset the whole system/satellite. When I started it up, it asked me to connect to the orbi guest network. Cant recall why. So I did - we were trying to set it up as a new network. As I went through the set up process, it defaulted BACK to our previous name we had given the network and it has been working just fine. All except that random ORBI guest network. When I look at the app, it says my guest network is off. So I suppose it is possible a neighbor has one too. It shows the strength pretty strong compared to all the other wifi connections. So I did not really think much about it.
