TonyTest's avatar
Feb 03, 2021
orbit Pro AX6000 Router + WAX610 AP , How to setup a same SSID just use the web ?
It is a office with 4 rooms, each room have wired port.   And  we have  one Orbit Pro AX6000 Router and 3 WAX610 AP.
We do not  use Netgear Insight Cloud and Insight APP.
Can I just use web browser to setup the router + 3AP to the same SSID in each room ?
  • BruceGuo's avatar
    BruceGuo
    NETGEAR Expert
    You need to configure each AP manually with the same SSID settings. That's one of reasons we developed Insight to make setup easier.
    • TonyTest's avatar
      TonyTest
      Tutor
        I can  configure 3 WAX610 AP manually with the same SSID settings as the AX6000 Router .   But there is no AC device in the LAN,  Is it  can support  Phone/Pad/Notebook roaming in deferent rooms  and automatic switching the AP ?
      • BruceGuo's avatar
        BruceGuo
        NETGEAR Expert
        I don't know why you need an AC device in the LAN. Generally wireless clients can roam and switch among APs with the same SSID and passphase.
ProSupport for Business
