TonyTest
Feb 03, 2021Tutor
orbit Pro AX6000 Router + WAX610 AP , How to setup a same SSID just use the web ?
It is a office with 4 rooms, each room have wired port. And we have one Orbit Pro AX6000 Router and 3 WAX610 AP. We do not use Netgear Insight Cloud and Insight APP. Can I just use web b...
TonyTest
Feb 03, 2021Tutor
HI, Kurt and Bruce,
There is some netgeart AC+AP solution for wifi5, like WC7600 + WAC720 in netgear.com .But no any AC model for WAX610, Does it mean that Wifi6 AP do not need AC.
Regards, Tony
schumaku
Feb 03, 2021Guru - Experienced User
Tony,
TonyTest wrote:There is some netgeart AC+AP solution for wifi5, like WC7600 + WAC720 in netgear.com .
These were controller based solutions, available with .11n and .11ac APs - dead end.
TonyTest wrote:But no any AC model for WAX610
Orbi Pro WiFi 6 and WAX610 are of course also supporting 802.11ac (and earlier standards) wireless devices - just like the NETGEAR consumer WiFi 6 devices do.
There are many more APs along with the WAX610, but with "just" 802.11ac support, for example the WAC505, WAC510, WAC540, or WAC564 which fit into the line, and be local Web UI as well as Insight managed of course, too.
TonyTest wrote:Does it mean that Wifi6 AP do not need AC.
I'm afraid, don't understand what you try to ask here.
-Kurt
- TonyTestFeb 03, 2021Tutor
Dear Kurt,
1, Can WAX610 use as AP for controller based soluntions , LIke one WC7500/WC7600 + n WAX610 ?
2, Can WAX610 use as a Stallite for the Orbi Pro AX6000 Router ?
- schumakuFeb 04, 2021Guru - Experienced User
TonyTest wrote:1, Can WAX610 use as AP for controller based soluntions , LIke one WC7500/WC7600 + n WAX610 ?
No. Local or Insight management only.
TonyTest wrote:2, Can WAX610 use as a Stallite for the Orbi Pro AX6000 Router ?
Only Orbit system matching Satellites can be used as Satellites.
My previous question to Netgear was intended to figure out if adding any WAC5xx or WAC6xx under Insight management would allow adding these as wired access points retainig the VLAN and WiFi features.
