TonyTest
Feb 03, 2021Tutor
orbit Pro AX6000 Router + WAX610 AP , How to setup a same SSID just use the web ?
It is a office with 4 rooms, each room have wired port. And we have one Orbit Pro AX6000 Router and 3 WAX610 AP. We do not use Netgear Insight Cloud and Insight APP. Can I just use web b...
TonyTest
Feb 03, 2021Tutor
Dear Kurt,
1, Can WAX610 use as AP for controller based soluntions , LIke one WC7500/WC7600 + n WAX610 ?
2, Can WAX610 use as a Stallite for the Orbi Pro AX6000 Router ?
schumaku
Feb 04, 2021Guru - Experienced User
TonyTest wrote:1, Can WAX610 use as AP for controller based soluntions , LIke one WC7500/WC7600 + n WAX610 ?
No. Local or Insight management only.
TonyTest wrote:2, Can WAX610 use as a Stallite for the Orbi Pro AX6000 Router ?
Only Orbit system matching Satellites can be used as Satellites.
My previous question to Netgear was intended to figure out if adding any WAC5xx or WAC6xx under Insight management would allow adding these as wired access points retainig the VLAN and WiFi features.
