wifiblues
Jul 22, 2021Luminary
outdoor satellite
hi - just purchased the RBK752 and I know that the RBS50Y has to be set up in Extender Mode - here is my question - When I go outdoors after the set up, will the satellite seamlessly carry the wifi s...
Jul 22, 2021Guru - Experienced User
it'll depend on your device and its own roaming protocol. The device (laptop/pc/phone) are what decides when to switch between access points.
- wifibluesJul 22, 2021Luminary
thanks Plemans,
another question -this time regarding the Extender network set up for the RBS50Y to use with RBK752 - do you have a guide on the steps for setting up the Extender set up?
currently, I am using the RBS50Y in Orbi mode with my RBR40.
- plemansJul 22, 2021Guru - Experienced Userthere's a guide for it :)
https://kb.netgear.com/000060131/How-do-I-set-up-my-Orbi-Outdoor-Satellite-in-Extender-Mode
